1993 Ford E-Series Van Van vibrates
1993 FORD E-SERIES VAN
185,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARTYC2
I just had brake work done on two rear wheels (new drums were installed) and front end work (tie rods installed). As soon as I picked van up from the mechanic I noticed alot of vibration when I hit 60-65mph. It seems to come from the rear since steering wheel is not shaking. I had 4 wheel alignment and all tires balanced to see if that would correct it. Its alittle better but still vibrates alot. This vibration problem was not there before I had the brake work and front end work done. Any suggestions to fix this problem?
Apr 4, 2008 at 3:41 PM
MASTERTECHTIM
  • 4,750 POSTS
sounds like the drums are over adjusted. when doing rear brakes with all new parts the tech will usually tighten the shoes a little extra to give you a good brake pedal. unfortunately it sounds like its a little too tight. you can jack up the rear end and spin the wheels, there should be little drag felt. hope this helps
Apr 4, 2008 at 5:14 PM
