1993 Ford E-Series Van oil
1993 FORD E-SERIES VAN
LONER777
Engine Mechanical problem
1993 Ford E-Series Van V8 Two Wheel Drive Automatic
hi yes i have a 1993 ford van and i recently started to have a horrible oil leak alot of ppl say its my oil pan but others say it sounds like a hole in my filter it doesnt leak much oil when it just sits sumwhere parked but like when i take it on the highway the oil sprays out to cover everything under the car and even sum of my back windows what do u think it could be
Aug 22, 2008 at 4:18 PM
KHLOW2008
  • 41,814 POSTS
Hi loner777,
It most certainly is a bad leaks and along the pressure lines.
Highest possibility would be bad seals either from the front or rear end of crankshaft or camshaft.
You need to check visually where the oil is leaking from. A cleanup of the leaked oils would make it easier to detect.
Sep 1, 2008 at 12:21 AM
