I need to install a new ignition switch and I would like to know how to remove the steering wheel. I has airbag in the steering wheel assembly. I di a switch in a 1989 van of the same type. but that one did not have an airbag in it. so I think I can handle that once the wheel is removed. but if there is a special application due to the airbag assembly, perhaps that info should be giving as well. does this van use the same type of switch as the 1989 model? if so I already have the switch.
Aug 8, 2009 at 4:55 PM
