inertia switch location
1991 FORD E-SERIES VAN
13,800 MILES • V8 • 2WD • AUTOMATIC
KPHIL4
Where is the fuel pump safety reset switch location on 1991 ford econoline van, if there is one?
[img:6294d14bce]http://www.2carpros.com/forum/automotive_pictures/151172_HandiCapsale001_2.jpg[/img:6294d14bce]
Jan 31, 2008 at 1:23 AM
The switch is called the fuel cut off inertia switch located under the right side of dash, on the heater plenum.
Here is a guid to help you test the relay
And the fuel pump relay is on the right front fender panel near the battery. See below
Jan 31, 2008 at 2:15 AM
RAMMAXSON
where can I find the fuel pump reset button?? on a 94 Econoline conversion van 57L V8 w/100K ml ??? and how much fuel should the fuel pump pump out with the filter disconnected. per revolution of the engine???
Nov 2, 2018 at 11:50 AM (Merged)
PEPPERMRJ
  • 1,158 POSTS
Don't know where the inertia switch would be. All the book says is that it is located in the cab. Try giving your dealer a call. There is no volume spec for fuel pump output. Measure pressure at the rail. Should be 35 to 45 lbs.
Good hunting and let us know where you find it. :)
JPTWOTIMES
  • 5 POSTS
where can i find one?
DOCFIXIT
  • 18,828 POSTS
Behind right kick panel underdash
