1990 Ford E-Series Van power to switch
1990 FORD E-SERIES VAN
146,000 MILES • 6 CYL • 2WD • AUTOMATIC
JEFFINVERO
My fan fan switch does'nt work..I checked power to the switch..none..I checked all the fuses..ok I changed all the fuses..nothing what could it be I need some help here ...THX jeff
Dec 15, 2009 at 6:27 PM
JUSTDON
  • 154 POSTS
The blower motor relay is probably out. It is a small three prong relay mounted on the radiator support on the battery side. You may have to lean in a little to see it. It is bolted on by two small sheet metal screws. Very simple change. But the part can be pricey for what it is. $40 in my area.
Dec 16, 2009 at 7:01 AM
