1990 Ford E-Series Van king pins
1990 FORD E-SERIES VAN
150,000 MILES • V8 • 2WD • AUTOMATIC
what's the correct procedure for changing kingpins? I was told that my wandering/loose steering problem was kingpins and cant find the procedure/parts anywhere. Couldnt it be the gear box or the column?
Sep 1, 2009 at 10:32 PM
ANJR
  • 32 POSTS
[quote:3546939c83="[email protected]"]Steering problem
1990 Ford E-Series Van V8 Two Wheel Drive Automatic 150000 miles
what's the correct procedure for changing kingpins? I was told that my wandering/loose steering problem was kingpins and cant find the procedure/parts anywhere. Couldnt it be the gear box or the column?[/quote:3546939c83]
The kingpins would be the last thing I'd suspect & you'd need the service manual + special tools to do that job right - it's not a Saturday afternoon in the driveway project.
1st thing I'd check would be the front tire wear & front end alignment - especially if you carry varying loads. The problem could be elsewhere & the steering box would be the next place to look, but since the front end camber changes from no load, to load in the front, load in the back, etc., the van can act pretty strange sometimes when there's really nothing wrong mechanically.
Somebody who really knows Fodr van/truck front ends can tell a LOT just by looking @ the front tire wear & checking the tire pressure - also knowing what (if anything) you carry in the van.
Sep 18, 2009 at 4:13 PM
