1989 Ford E-Series Van power windows
1989 FORD E-SERIES VAN
82,134 MILES • V8 • 2WD • AUTOMATIC
CARPVINYL723
  • 4 POSTS
the power windows work very weak they need help up or down ,this van is new to me so not sure how long this has been going on?
Aug 5, 2010 at 6:19 PM
HMAC300
  • 48,601 POSTS
try taking the door panel off and lubing the rollers and the gear on the power window. you only need to smear some grease on the gear. then spray some silicone in the runners on teh ends of the windows when you have them down. that usually takes care of it...
Aug 5, 2010 at 6:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
sounds like power window motors are about shot or the tracks are just rusty/dirty and need lubrication. remove door panels and lube them up to see if it helps.
