I'm trying to sort out a bug on my RV. On a 1988 Ford E350 chassis with a 460, I have a problem with the cab A/C blowing thru the vents on the dash at idle or high vacuum, but when pulling a grade or accelerating/low vacuum the dash vents close and the cold air goes elsewhere. I sorta know the following....
The system is operated by vacuum.
There is a leak somewhere.
The check valves in the lines seem to be working/flow in one direction.
The question is, is there a generic problem to this system that should be checked first? I am trying not to pull everything apart for no reason and the E350 van is packaged pretty tight under the hood. My Clymer book has no clues. Any ideas?
Thanks
Jeff
Thanks
Jeff
Mar 31, 2009 at 3:57 PM
