1986 Ford E-Series Van timing won't advance
1986 FORD E-SERIES VAN
DANO 76
Electrical problem
1986 Ford E-Series Van 6 cyl Two Wheel Drive Automatic
with a tfi ingnition system witch component typically is failing when timing won't advance?
Jan 13, 2009 at 9:18 AM
DAVE H
  • 13,384 POSTS
Profile Ignition Pick-Up (PIP)
The PIP informs the ECA of crankshaft position and speed. PIP assembly is integral with distributor on all models. PIP has an armature with 4 windows and 4 metal tabs that rotate past a stator assembly (Hall effect switch). Ignition distributor does not have any mechanical or vacuum advance.
Jan 13, 2009 at 9:22 AM
