1979 Ford E-Series Van Losing Spark
1979 FORD E-SERIES VAN
165,000 MILES • V8 • 2WD • AUTOMATIC
RV LUCKY
  • 8 POSTS
Have replaced the actual key switch, all plugs, wires, cap and rotor, coil and module. Starts and runs but then shuts down. Checked for spark and when the key is turned on I get a spark, and another when turned off. No spark when actually cranking. After a few minutes I will get spark back and will start. Does not shut off while going down the road at high rpm, only at low rpm, when slowed down and stopping or turning. This is a small RV that sat for over a year in a tow lot.
Jul 17, 2009 at 12:33 AM
RACEFAN966
  • 5,029 POSTS
Ok on the fender or near the battery there is a starter solenoid it should have the poss battery cable going to it and then from it to the starter then there is an S term and and I term are you useing both of these smaller term? If so then I would like you to check for power at the I term duing crank when you don't have spark. Let me know what you find.
Jul 17, 2009 at 8:58 AM
RV LUCKY
  • 8 POSTS
Ok, turn key on and have power at I term, crank and test light gets brighter, stop cranking and light stays on, turn off key and light goes out.
Jul 17, 2009 at 8:53 PM
RACEFAN966
  • 5,029 POSTS
Ok what I need you to do is check ohm's of resistance at the coil check resistance between + and - terms then check resistance between the + and the center and the - and the center. Let me know what you find.
Jul 20, 2009 at 5:15 PM
RV LUCKY
  • 8 POSTS
+ to - Ohm= 1.4
+ to center Ohm = 9.73
- to center Ohm = 9.73
Jul 20, 2009 at 10:35 PM
RACEFAN966
  • 5,029 POSTS
Ok the coil ohms out good to it isn't a bad one. Now if you would unplug the the distributor harness and then ohm the pick up coil. Just simply ohm it across the term in the distributor plug you should get 400 to 1000 ohms if not the pick up coil is bad and needs to be replaced. Let me know how it goes.
Jul 21, 2009 at 9:02 AM
RV LUCKY
  • 8 POSTS
648 Ohms cold. Always dies when I warm it up, so started her up and got her good and warm... ALWAYS starts when shes cold... Shut it off for 5 minutes and tried to restart, nothing. Crank no start. Re-chech Ohms and I get no reading.?? That sound like a bad distributor? Got to be loosing connection or something to not get a reading right?
Jul 21, 2009 at 3:13 PM
RACEFAN966
  • 5,029 POSTS
It is the pick up coil in the distibutor causing this. When it gets warm it is loosing continuity and so no spark. Now you can replace the pickup coil itself or the distributor if you don't want to take the distibutor apart to replace the pick up coil. Let me know how it goes.
Jul 21, 2009 at 8:55 PM
RV LUCKY
  • 8 POSTS
Purchased a pick up coil from my local NAPA store, took about 20 minutes to install. Now for some reason I can't get it to die???
Thaks a WHOLE bunch for all your help, coudn't have done it without you.
Jul 22, 2009 at 3:41 AM
RACEFAN966
  • 5,029 POSTS
Great it lives and thanks for being pateint with the tests to make sure what was wrong. Thanks again for you support and have a wonderful day.
Jul 22, 2009 at 9:30 AM
