valve seal replacement on 1990 ford crown vict. 5.0L
1990 FORD CROWN VICTORIA
NEWYORKER
  • 7 POSTS
hi,
i have a 1990 crown victoria wagon, mileage 177,290
would anyone know what psi i have to set for output on the compressor to hold the valve stems while replacing the valve seals in the engine? Any reply would be appreciated.
thank you
May 23, 2006 at 4:07 PM
NAI1ER
  • 15 POSTS
Not every one has access to a compressor or the proper fittings for the job.
My favovite ( and almost fool proof ) way is to remove the spark plug and fill the cylinder with clothes line. Get as much line in there as you can. Leave the end hang out for removal. Rotate the engine until it won't turn any more this forces the line against the bottom of the valve holding it firmly in place. When finished rotate engine backward and remove line. Repeat on next cylinder.
GOOD LUCK
Nai1er
May 24, 2006 at 7:16 PM
