Idles High when Heat, A/C, or fan is on.
FORD CROWN VICTORIA
JUST_GRETA
  • 7 POSTS
Hi. I have a 1994 Crown Vic that idles high when the heat, a/c, or even just the vent fan is turned on. Any ideas? Thanks!
Oct 6, 2007 at 3:10 PM
JAY6647
  • 17 POSTS
[quote:51ca84654d="just_greta"]Hi. I have a 1994 Crown Vic that idles high when the heat, a/c, or even just the vent fan is turned on. Any ideas? Thanks![/quote:51ca84654d]
If you could provide more information on the
problem, maybe me or someone on this forum could help you better.
1) RPM's on Idle (a/c off)
2) RPM's on idle (a/c on)
3) Is the engine running smooth or rough(misfire)
4) Does it over-heat at anytime?
5) Does it make sounds that are not normal?
6) Does it drive fine with a/c on or do you have loss of power?
7) Any warning lights on the dash?
Thank you.
Jay
Oct 6, 2007 at 3:26 PM
JUST_GRETA
  • 7 POSTS
Hi. You know what...when I went out and drove it to get this info, it wouldn't do it for me! Anyway, as soon as I am driving it and it does it again, I will come back and post this info.
Thanks!
[quote:53c92a5616="JAY6647"][quote:53c92a5616="just_greta"]Hi. I have a 1994 Crown Vic that idles high when the heat, a/c, or even just the vent fan is turned on. Any ideas? Thanks![/quote:53c92a5616]
Thank you.
Jay[/quote:53c92a5616]
Oct 6, 2007 at 7:42 PM
