2003 Ford Explorer 4.0L Eddie Bauer 30,000 miles
Rear vibration at 60 mph and faster. Still there after letting off throttle, still there in neutral. Due to some tsb's Ford has replaced crown and pinion in rear diff with updated one, and has replaced drive shaft with update, neither helped. Was told it must be a tire problem. Rotated tires, same problem. Replaced left rear outer tie rod and end, was told it was a bit worn, same problem.Was told tires may all be bad, so I bought all new tires, high speed balanced to " zero"so they said, still have the same problem. I'm going crazy, broke, and very frustrated. What else could this vibration be?
Dec 28, 2006 at 12:40 AM
