drivetrain malfunction when driving
FORD CROWN VICTORIA
OICGHD
my 2000 crown vic ( 61000 miles ) has been having intermittent and worsening problems shifting from lower speed gear to higher speed gear. It starts off great in first gear, then when shifting into second it seems to fall into neutral for about 1-5 seconds, the temperature light shows overheating, and then traction control light turns on, and then ( finally )drops into second.
the car was sent to autolab for more than one week
and spent $200 for repair. it still has the same problem.
any help is highly appreciated.
Feb 27, 2006 at 6:14 PM
LOVESCARS
  • 359 POSTS
have trans serviced if not already done could be valave pressure body sticking
Feb 27, 2006 at 8:20 PM
OICGHD
[quote:dd7b8981be="Pud"]have trans serviced if not already done could be valave pressure body sticking[/quote:dd7b8981be]
Thanks for your kind help.
I had trans flushing done when I noticed the problem.
It gets worse even after trans flushing.
Could it be other problem?
Feb 28, 2006 at 7:29 AM
LOVESCARS
  • 359 POSTS
You'll need to take it to the delaer
Feb 28, 2006 at 11:05 AM
