Battery Light still on, low volt reading
FORD CROWN VICTORIA
DUVALPR
I have a 1993 for crown victoria lx with 72,748 miles on it. I just put a new alternator in it along with a new battery, when i start it up my battery light is on and the voltage meter on the display is very low what is causing this problem?
Nov 11, 2007 at 6:37 PM
Get it load tested both battery and alternator. It could be the alternator not putting out or the battery is not taking the charge.
Double check all connections at the battey and behind the alternator.
Just because its new there's such thing as manufacturers defects.
Nov 11, 2007 at 7:26 PM
CROWN-VIC
1. Make sure you have the right alternator. At least 130 amp but 200 recommended. (Depending on electric components in the car.)
2. When you install a new alternator, the battery MUST be FULLY CHARGED before the car is started. If this is not done, the alternator will over-heat very quickly and be rendered useless. The rotor inside the alternator spins extremely fast and the centrifugal force applied to it causes its wires to spread, thus touching the inner walls of the alternator's shell, at which point your car will shut off. This is called "grounding". Your alternator may be grounding. If it is, then its creating sparks as it spins which is very dangerous on a CV.
Remember though, this is a possibility. Make sure you check the simpler components such as connections and such first. If thats all good, then heed #2 above. I truly do not see what else it could be.
I too had the same problem on my 97 crown victoria. I had the alternator returned for a brand new one, charged my battery full, and started her up. No further problems. :D
Nov 17, 2007 at 11:52 AM
Did you check these fuses: 1. STR Alt 30amp in the engine compartment fuse box. 2. Instrument Panel fuse box No. 16 10amp.
Nov 17, 2007 at 3:16 PM
