97 Crown Vic. runs rough
1997 FORD CROWN VICTORIA
WEAREA2J2
  • 43 POSTS
97 Ford Crown Victoria 4.6L 118,000 miles. This car is an old police car out of Florida. I live in the midwest and the car gives me grief when the weather gets cold. It does not want to start and when it does it will run rough and run rich until it starts to warm up. I replaced bank 1 sensor 2 o2 sensor and that helped for awhile, until it started getting chilly again. The check engine light keeps coming on telling me it is the sensor I replaced and air/fuel metering. I am not sure what the latter means since it is fuel injected. I also have cleaned the MAF sensor and the other one in the air filter box. The intake manifold has also been cleaned. Any help would be greatly appreciated!!
Nov 11, 2006 at 10:04 AM
CATCH_15
  • 250 POSTS
Even though you cleaned the mass air flow sensor, that won't help if it has gone bad. Try replacing it and see how it does. They tend to go bad on Ford vehicles a lot.
Nov 11, 2006 at 11:25 AM
WEAREA2J2
  • 43 POSTS
Would a MAF Sensor failure make the check engine light come on? If so, it has not shown up in the computer. THX
Nov 12, 2006 at 10:32 PM
CATCH_15
  • 250 POSTS
Yes, that would definately make the check engine light come on. I have a 5.0 Mustang and my MAF was bad and the code reader just read "error".
Nov 12, 2006 at 10:50 PM
WEAREA2J2
  • 43 POSTS
The check engine light is on now, and the codes are for the o2 sensor I replaced and air/fuel metering. My tech manual doesn't say anything on the subject of metering. Nothing about MAF Sensor.
Nov 12, 2006 at 11:05 PM
CATCH_15
  • 250 POSTS
If the code says O2 sensor, try replacing them and see how it does. If they are bad, they'll throw off the air/fuel mixture which will make the car run rough.
Nov 12, 2006 at 11:28 PM
WEAREA2J2
  • 43 POSTS
I replaced the one that the comp. said was bad, but at $80.00 each I didnt want to go broke either. The metering code didnt come in till after I had replaced the bad one.
Nov 13, 2006 at 12:08 AM
CATCH_15
  • 250 POSTS
So, did you get the trouble code for the sensor after you replaced it? If so, that doesn't make any sense to me. Which sensor and bank did you replace? Yes, I know they're expensive, I have a Mustang with the 4.6 and had to replace two of them.
Nov 13, 2006 at 12:16 AM
WEAREA2J2
  • 43 POSTS
Thx for all of your help but I traded the car in. Let someone else figure it out!? I was also told that the brain was probably getting ready to go!!
Jan 14, 2007 at 6:33 PM
