location of ac relay
2007 FORD CROWN VICTORIA
LOSTWOLF
where can I find out whitch one is the ac relay
Jun 15, 2010 at 5:48 PM
WAY2OLD
  • 195 POSTS
The A/C relay is located in the battery junction box.... right front of engine compartment behind the battery
Heres a guide to help you test it
See the full wiring diagram below and AC clutch relay in the third diagram.
Jun 15, 2010 at 6:37 PM
ASVENTU
  • 14 POSTS
ford crown victoria 2004. 158,194km.the low side hose in the engine compartment too much cold,but it blows hot air inside the car. DTC B1249. blend door fail or short. where is the location of the blend door?
Jul 27, 2019 at 10:46 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Blend door actuator is under the dash and for removal, you would need to remove the instrument panel.
ASVENTU
  • 14 POSTS
sir,thank U for the suggestion.I removed the instrument panel and i replaced the blend door actuator w/ a brand new and original parts.but still the actuator not working.can you show to me pls.even just a simple wiring diagram from a/c control switch to to blend door actuator.thank you so much.
KHLOW2008
  • 41,814 POSTS
Here are the schematics. If you require the diagnostic procedures, let me have an email.
ASVENTU
  • 14 POSTS
Sir,thank U so much for the diagrams of the EATC. here is my email add. [email protected] Can U pls. send to my email the diagnostic procedure of the EATC and the schematic diagram as well so that i can print it? I am a filipino from philippines working here in saudi arabia.thank U very much and more power.
DAOVIC
The AC shuts off above 90 degrees. Filled the Freon with the proper pressures 45-55 psi. After running, it shut off with low pressure above 165 psi. Brought psi down to avoid damage to the low side of the system.
Please advise. From what I have seen, problem may be an inoperative expansion valve. Where is it, and how is it replaced? Is this a DIY, or Shop required?
Never used this site before.
Thanks
BUDDYCRAIGG
  • 2,262 POSTS
I'm going to have to ask you a lot of questions.
Even though you said a lot of stuff, you left a few little things out with each statement.
the AC shuts off above 90 degrees.
When what is above 90 degrees?
How does the AC shut off?
is the compressor clutch disengaging?
or
is the compressor still running but the air out the vents is warm?
KHLOW2008
  • 41,814 POSTS
File has been sent. Hope it turns out well. Good luck.
DAOVIC
Buddy -
The ambient temperature is about 90 degrees. The AC cools until running for a while, then shuts down.
The compressor shuts off.
I checked the pressure for the first time yesterday. This was done after filling the low pressure side until it reached 50(+ or -) psi, with the ambient temperature around 85. I ran the car for a while and the compressor shut off. I searched the Internet for similar problems and found that the cause may be the expansion valve/orifice. I checked the pressure (low side) and it was around 165 psi. Seeing that this was the low side and did not want damage done, so I reduced the pressure back to around where it started before filling (around 25-30 psi).
Thanks,
DAOrner
ASVENTU
  • 14 POSTS
Sir,i already got the diagnostic procedures that sent to my email. and i done the step by step procedures and i found the problem.there is one open wire from the EATC module going to the blend door actuator.I repair it and now it is working good. thank U so much and also for the very informative website WWW.2CARPROS,COM.more power.
BUDDYCRAIGG
  • 2,262 POSTS
if the low side was at 50 with the compressor running, then you have 3 possibilities.
the compressor valves are weak.
the expansion valve is not closing.
you have too much freon in the system.
If you can tell me what the high side readings are, it will help rule out having too much freon.
the low side can get to 165 when the engine is off and the under hood temps are in the 220F range
And PS, 25~30 is where you want the low side to be with the compressor running.
KHLOW2008
  • 41,814 POSTS
You're welcome.
Glad to know you have fixed the problem.
DAOVIC
The engine was running with the low side @ 165 psi and the compressor shut off (AC still on).
The hood was open, outside ambient was 85 degrees. Temp under hood was well under 220 degrees.
The instructions on the can show low pressure 45-55 psi @ 85 degrees ambient.
Do not have a dual guage (simple low side refill kit).
Thanks
BUDDYCRAIGG
  • 2,262 POSTS
[quote:7c1a855876="daovic"]
The instructions on the can show low pressure 45-55 psi @ 85 degrees ambient.[/quote:7c1a855876]
that would be for a charged system, [b:7c1a855876]without[/b:7c1a855876] the compressor running.
I just checked my quickie chart and r-134 would be 165psi at 118F without the compressor, so that's totally believable.
go get yourself a cheap set of gauges.
I paid $40 for my first set and they lasted 6 years.(other than the plastic knobs cracked and had to be replaced.)
right now, we dont know why the compressor is shutting off. knowing high side readings would help narrow that down.
the high side could be getting too high and a pressure switch is tripped,
or
the evaporator is freezing up
