2006 Ford Crown Victoria Headlamps
2006 FORD CROWN VICTORIA
39,600 MILES • V8 • 2WD • AUTOMATIC
JUDYKUHTENIA
How do i adjust my headlamps
Aug 6, 2008 at 9:06 PM
ZPOLACHEK
  • 16 POSTS
This is an easy one. Open your hood and remove the plastic cover over your radiator crossmember to access the back of your headlamps. you should see two black metal strips with pull tabs up against the back of the headlamp assembly. pull up on the strips until they unclick/lock. then rotate the adjustment screws on the strips accordingly to move your/adjust your beams. once finished then push the strips back down until locked and replace the plastic cover. Its pretty simple to do once you get in there, just make sure you do it with a friend so that you can get a second opinion on light placement. Some people tend to adjust way off so grab a beer and a friend and make a short afternoon project of it.
Oct 10, 2008 at 1:11 PM
