2003 Ford Crown Victoria NOT CHARGING, ALTERNATOR PROBLEM
2003 FORD CROWN VICTORIA
120,000 MILES • V8 • 2WD • AUTOMATIC
RICK SALYER
INSTALL NEW ALTERNATOR. AFTER 2 MONTHS
CAR QUITS CAHRGING, CAR IS A X POLICE CAR
HAS A 130 AMP ALTERNATOR ON IT
Jan 10, 2008 at 12:38 PM
IZ1111
  • 13 POSTS
If you still have an old battery, and you get a new alternator. You kinda force it to adapt to different a adjustment and you may have pushed it too far. Either your battery stopped taking a charge because of age or the change of input energy. Or you just burned up your new alt. for making it charge an old, undercharged battery.
Feb 19, 2008 at 8:22 PM
JMUGGE2000
Check the cable that runs from the alternator to the power distribution block. Make sure it is tight. I have a 99 Police interceptor and my wire actually was melting my B.U.S.S. Bar cause of a loose connection.
Nov 16, 2008 at 3:22 PM
