Not cranking over
2003 FORD CROWN VICTORIA
Car has been sitting for a while. The battery was low so I charged it and the engine radiator fan started running even without a key in the ignition, When I turned the ignition on, all the lights on the dash started blinking but car still will not start. Just clicks. What can I do.?
Aug 28, 2010 at 4:07 PM
It sounds like you have a starter that is not working but to be sure lets run down this guide to confirm the failure.
https://www.2carpros.com/articles/starter-not-working-repair
Aug 28, 2010 at 6:43 PM
MAHENDRA DAHYA
Thanks for this post I went through the guide and found the starter was bad got a new one for $134.00
Jan 22, 2019 at 8:02 PM
SJIMFL
everything is fine,except the starter does not get any electrical current
could it be the starter relay?
Jan 22, 2019 at 8:03 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
check solenoid beside battery and neutral safety switch
IRVINGANDERSON
It cranks but won't turn over, I think it's a fuse but don't know what fuse it is
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coils resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
WAKESK888
  • 21 POSTS
My car has been sitting in the drive way for a year an has been getting cranked every month to keep the battery good an so on. Now the car will not crank. You can smell the gas going into the engine but the car wont turn over?
WAY2OLD
  • 195 POSTS
If you jump the car from another, will it start?
WAKESK888
  • 21 POSTS
No it will not start when I jump it from another car. I disconnected the fuel line from the fuel tank an it seem there is a clog in the line or fuel pump
WAY2OLD
  • 195 POSTS
Can you hjear the fuel pump running when the key is turned to the on position? There is also an inertia switch in the trunk. Make sure the red button is locked in the down position. The fuel pump relay is also a known failure on these cars.
WAKESK888
  • 21 POSTS
Where is the inertia switch located in the trunk?
WAY2OLD
  • 195 POSTS
Left side close to where the trunk hunge is. It is a little square box that has a button on the top. If fuel is good, check for spark. No spark, look at the crank sensor. Also check the wiring under the right front bumper area under the battery, There is a loop in the wiring where water collects and will corrode wires.
MRCROWNVIC
  • 4 POSTS
Engine Performance problem
2000 Ford Crown Victoria V8 Two Wheel Drive Automatic
Recently i parked on a moderate slope, leaning toward the drivers side. The low fuel light had been on for 10 miles, i can go about 40 miles before i'm in trouble of running out of gas. I live in Lexington, SC and the low is 50 and the high is 70. Fuel filter was replaced 15,000 miles ago. It will crank fine when i go to work @ 9am. But when i go home @ 5pm. it takes 30 seconds to 1 minute of steady holding the key for it to crank. I do not want to ruin a starter, battery or etc. because of this recent problem. This is the 4th day of this occurrence.
First, don't crank the engine for more than 10 seconds at a time. It will burn up the starter. Second, does this problem happen when there is a lot of gas in the car too? Finally, has the check engine light come on?
WAKESK888
  • 21 POSTS
I found the inertia button an it was tripped. the button wouldn't release when i followed the instructions in the manual an it would release untill i hit the little black box that its in. The car is still tring to turn over but its not working.
MRCROWNVIC
  • 4 POSTS
The low fuel light was on when it was parked leaning toward drivers side when it first started doing this. I thought that it being low on gas, it was not getting fuel to the pump, so i filled it up. I checked my records and the fuel filter was replaced 30,000 miles ago not the 15,000 i previously stated. I aked my local mechanic to use his Snap-on diagnostic machine to see if he could find out anything, and he said unless there is a light on like the check engine it would not do any good. I can replace the fuel filter, but how do you tell if the fuel pump has been clogged with trash. I would hate to replace a fuel pump and not solve the problem. Thanks for your time and consideration.
It could have damaged the fuel pump. Here is a how to video and instructions for checking fuel pump pressure. Let me know what you find.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
You will need a gauge to check it. Most parts stores will lend or rent one to you.
MRCROWNVIC
  • 4 POSTS
I put a new fuel filter on Monday and added an STP fuel injector cleaner. Its been 24 hrs. and no cranking problems. Thanks for the info and help i appreciate it.
I'll keep my fingers crossed for you. Good luck and let us know if you have qustions in the future.
WAKESK888
  • 21 POSTS
I just replaced my battery because it wouldn't hold a charge, an I replaced the fuel filter too. My car still wont turn over. I checked the fuel filter an its not getting any gas now an theres no gas runing threw the lines into it? Does this mean its the fuel pump. The inertia swith is fine.
MRCROWNVIC
  • 4 POSTS
Thanks for all the help.
If you have fuel in the tank, chances are the fuel pump is bad. You will need to check and make sure it is getting power. Let me know what you find.
WAKESK888
  • 21 POSTS
I got it fixed. it was the fuel pump
Glad you got it fixed. Based on your description, that is what it sounded like.
Take care and let us know if you have questions in the future.
MDJENKS36
Car turns over but won't start sometime act as if wants to start
Have you checked for spark and fuel to the engine?
LADIIE
2000 Ford Crown Victoria V8 156000 miles
I have a Ford Corwn Vic 2000 police model, I drove the car the day prev and woke up the next morning to get ready for work and the car will not start.. It has fuel, we`ve checked the fuels and they are fine.. What can be the matter with the car?
Jan 22, 2019 at 8:04 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Does it crank put no start
have fuel did you check for fuel pressure
do you have spark
if not sure how to do all this check our video collection in the at home page
REEBA
Electrical problem
2004 Ford Crown Victoria V8 Automatic 98000 miles
Starter Ok. This is a ford crown vic interceptor. Can start car by crossing the terminals on starter motor. I've replaced ignition switch. Are there any fuses I missed checking? Checked main fuse box. There are black fuses that you can't read. Could this be the problem or is it something else?
Hi:
have you checked the starter relay?
