I have a 2003 Ford Crown Victoria with 81,000. I had a misfire code for cylinder 3 the other week. I replaced the Coil over the plug with a spare, cleared the code and the car ran great for about 50 miles and 3 days. Next time I drove the car I received another misfire code for cylinder 4. I checked the coil/plug and everything is good. The only time the car runs rough is if I'm sitting in drive for about 2 minutes, then it starts to run rough and after about a block, it runs great. I currently show misfire codes on cylinders 4, 5, and 8. I checked for a crack in the plastic manifold cross over and everything is good, no leaks. All coil boots/plugs/plug wells do not have any moisture or signs of arched current. I'm baffled, please help.
Thank you for your help.
Jan 29, 2009 at 4:09 PM
