2002 Ford Crown Victoria Squeaks/chirps from front end
2002 FORD CROWN VICTORIA
69,200 MILES • V8 • 2WD • AUTOMATIC
THE253
I have a 2002 Crown Vic Police Interceptor. A couple months ago, I noticed intermittent squeaks or chirps coming from the driver side front wheel, I believe. It started only when going over uneven road surfaces or small pot holes, but now it is pretty consistant on any surface. I also notice it when I get out of the vehicle and close the door. I'm not sure if it is the suspension or what the issue is. Also, about a week ago I had my oil changed and now all of a sudden I am hearing a clicking or ticking coming from the passenger side rear wheel. It almost sounds as if there is a stone caught in the tread. I inspected the tires and there isn't anything apparent, the tires were not rotated, so I don't believe that the lug nuts are loose. It's driving me crazy and I'm becoming concerned about the noises. Can you please help??
Aug 12, 2009 at 11:28 PM
BMRFIXIT
  • 19,053 POSTS
Check outer tie rod and ball joints for the front noise
remove rear tire and check brakes
Aug 13, 2009 at 5:58 AM
