2001 Ford Crown Victoria Drivers window wont work
2001 FORD CROWN VICTORIA
11,500 MILES • V8 • 2WD • AUTOMATIC
WAKESK888
  • 21 POSTS
All the windows are working except for the drivers door. I check the fuses an there are all good. When i push the button to roleup/down you can hear a little clicking noise inside the door?
Apr 22, 2010 at 8:21 AM
WAY2OLD
  • 195 POSTS
You are probably going to need a window regulator. Remove the inside door panel and you will probably see where the cable has come out of the housing.
Apr 22, 2010 at 6:26 PM
