2000 Ford Crown Victoria knocks
2000 FORD CROWN VICTORIA
110,000 MILES • V8 • 2WD • AUTOMATIC
WILL20
a couple of days ago i noticed a knock comeing from some were in the engine i could not figure out from the exact poit but it only happend when i gave it a little gas if i gave more gas it went away until today it was not a proble it does not make the noise while idleing but if u give it gas it sounds horrible i was told it was the lifter or the rod whats youre opinion
Dec 29, 2008 at 1:12 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
A faulty lifter will tick, but if you are developing a bearing problem this will knock, it will be a deep and hollow sounding knock and it will be constant with engine speed, i would get a mechanic to listen to it ASAP as if it is a bearing problem you run the chance of destroying the engine if you let it go on for to long.
mark (mhpautos)
Dec 29, 2008 at 1:41 AM
