I checked compression consitent on all cylinders,checked fuel rail pressure very good,changed the injectors and tested them nice cone of fuel,new spark plugs,changed coils twice,cleaned fuel rail with a professional pressure cleaner and solution.checked spark with tester ok.Pulled valve cover and changed lifters and push rods checke lobes on cam good,cranked motor valves opening and closing like they should but still missing on both cylinders.these cylinders as far as i can see have fuel and spark and good compression and still is missing.This car ran perfect than ran out of gas and started missing.first it dropped 6 pushrods from gas gum but not on these cylinders i fixed all of them by cleaning and replacing push rods and making sure the valves were opening and closing correctly.If you have any idea let me know.Thanks Junior2 I will be glad to donate which i have done on other sites but they were unable to help me.You tell me how to fix it and i will be very happy to make a donation,thank you
Aug 28, 2009 at 12:20 PM
