1998 Ford Crown Victoria Car will not start
1998 FORD CROWN VICTORIA
123,000 MILES • V8 • 2WD • AUTOMATIC
CARLTONC
The car motor turns over and catches for a brief moment then dies out. I tried to start until the battery died. What do you think it can be? It is probably not the batery, starter, or alternator. I have been told it is probably the fuel pump. Also can you tell me where the fuel pump is located?
Oct 23, 2008 at 9:19 PM
HONDA_MASTER
  • 6 POSTS
I had the exact problems with mine. I have a 98 crown vic police interceptor and I was driving down a rough road and it triggered the fuel pump shut off switch that's located in the trunk. So I would recommend looking on the inside left of the trunk for a box with a red button on top. Make sure that button is pushed down. It's like a breaker in a way. If the button is up just push it down and the fuel pump will work again, only if that's the problem. The fuel pump could be broken also.
Nov 1, 2008 at 12:53 AM
