1997 Ford Crown Victoria (secondary) bolts, caliper mount b
1997 FORD CROWN VICTORIA
100,000 MILES • V8 • 2WD • AUTOMATIC
DEACONSBENCH
The caliper is off, now I'm trying to remove the caliper mount bracket so I can replace the rotor. I have been beating on these two stuck bolts for 2 days now. Would they happen to be reverse threads?
Mar 1, 2010 at 10:22 AM
MERLIN2021
  • 17,250 POSTS
No! They have locktite on the threads, either heat them with a tourch, being carful not to burn the ball joint dust boot, or use a long handle 1/2 drive ratchett wrench and use a quik slapping motion...
Mar 31, 2021 at 11:11 AM
DEACONSBENCH
Thank you! The torch had to be applied twice, but they finally gave up the ghost with minimal wear and tear.
