Hello! On very hot days when I am running the AC my engine will run rough, as if a cylinder is not firing. It will continue to run, not stall, with a steady check engine light. After a while it will start to run good again (especially if I get it up to highway speed for a while)... I re-set the check engine light and all is well to it happens again... (Temperature meter reads OK, mid-range) I suspect it is a coil-pac or maybe a relay. I have cleaned out some rust under the coil packs and have swapped the relays around... I am still testing... Wires and plugs are good (new)... What do you suggest??? I am thinking New Coil Packs, Relays and Diode... ???
Mar 19, 2009 at 8:20 PM
