1997 Ford Crown Victoria Mech cannot detect probelm
1997 FORD CROWN VICTORIA
159,000 MILES • V8 • 2WD • AUTOMATIC
MRDAVIS
Have this car presently at shop with 2 master mech with much expericance the story goes like this, car running fine, I changed oil, cleaned the battery cable of rust on neg side only. After starting it up, the engine idiels fine, yet, it dogs out when giving it gas and it will not get any power. The mech and went through and triple check all normal problems yet, come up with no answer. Please advise if possible?
Apr 10, 2008 at 3:24 PM
MASTERTECHTIM
  • 4,750 POSTS
recheck the battery connections and replace terminal ends if you have to. also try unplugging mass air flow sensor and see if that makes it ruyn better, if it does then replace it.
Apr 10, 2008 at 3:27 PM
