i have a 1997 crown victoria police interceptor and i have no power to the fuel pump. i have jumped a hot over the inertia switch and runs fine. i checked the relay... replaced it... and checked the wires. i have power coming into the relax distribution box but no power coming back out to the pump. when i jumped over the inertia switch i rechecked the wires on the back side of the block and had 3 or 4 wires hot...(keep in mind i jumped power from the trunk light) however when i took the power jumper wire off and checked again i only had 1 of the 4 wires running hot.... the one powering the relay. no idea where to go from here some help would be awesome ... thanks in advance. after thinking about it im thinking the relay should have a constant hot a ignition hot a ground and the fuel pump wire. which i only have a constant... so if i power the 3rd wire that was hot when i jumped it it should trip the relay on...please if anyone knows either confirm of repute this statement.
Jan 14, 2010 at 5:50 PM
