1997 Ford Crown Victoria fuel pump
1997 FORD CROWN VICTORIA
130,000 MILES • V8 • 2WD • AUTOMATIC
DONEDEAL
  • 6 POSTS
i drove this car 3 days ago and have never had any problems .It turns over fine so i sprayed some starting fluid in the intake and it fired.so that means its got firing but not getting gas.and i turned the switch on and i never could hear the fuel pump. so could the pump just go bad just like that?
Apr 14, 2010 at 7:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
prob. a fuse or something. check fuse and fuel pump relay. if OK may need to test pump with 12v direct power.
Apr 14, 2010 at 7:56 PM
Could be with that mileage. Start by checking the inertia switch if okay check fuel pump fuse and fuel pump relay both okay, power the fuel pump direct from the battery if it doesn't come on and ground is good-it went south.
Apr 14, 2010 at 7:58 PM
DONEDEAL
  • 6 POSTS
what is the inertia switch? and where is the fuse i found the pump relay
Apr 14, 2010 at 8:39 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check fuse labeled FUEL PUMP (20 amp) in the engine compartment fuse box. the inertia switch is a safety fuel cut off switch and is located in the trunk, on the left support.
Apr 14, 2010 at 9:11 PM
DONEDEAL
  • 6 POSTS
ok i checked the fuse its good and i pecked on the relay but how can i strait wire the fuel pump?is it not in the tank.
Apr 14, 2010 at 9:51 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yes have to remove it..you can bench test it. It's not good to run them for more than a second or 2 with no gas because they are actually gas cooled and lubricated. But you can touch power to them briefly to make sure they at least turn.
Sometimes you can resurrect a 'stuck' pump just by whacking fuel tank with a piece of wood (don't hit it hard enough to dent it!!).
Apr 14, 2010 at 9:53 PM
DONEDEAL
  • 6 POSTS
could i tap in to the wire at the relay and jump it from the battery
Apr 14, 2010 at 9:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
yep that will work if you want to splice into the wiring
Apr 14, 2010 at 10:00 PM
DONEDEAL
  • 6 POSTS
there are 3 relays and a diode so theirs several wires do u have any idea what color wire i need to splice to test it
Apr 14, 2010 at 10:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
red wire should be
Apr 14, 2010 at 10:08 PM
DONEDEAL
  • 6 POSTS
thanks guys i really appreciate all the help
Apr 14, 2010 at 10:44 PM
