Engine Performance problem
1995 Ford Crown Victoria V8 Two Wheel Drive Automatic 143k miles
Will an clogged egr valve cause my car to seem like the transmission is shifting into 2nd gear too soon or slipping on take off ? If I hold the brakes down and push the accelerator it doesn't slip or feel like the transmission is going t, but when I take off if I press the excelerator hard then it feels like the transmission is slipping or going out. I think the mechanic told me the diagnostic code was P-31 insufficient EGR air flow. How do I manuelly check the EGR valves without tools, and how do you lift the EGR valve to see if I need to replace it ?
Mar 9, 2008 at 11:21 PM
