1994 Ford Crown Victoria changing battery cables
1994 FORD CROWN VICTORIA
162,000 MILES • V8 • 2WD • AUTOMATIC
BNSW1
I have disconnected the battery cables from the battery and the starter but can't get it the cable out it is hooked to something else on the back of the engine but can't see it i checked my manuel and it don't tell you how to take it off can you help thanks
Feb 16, 2009 at 10:16 AM
DAVE H
  • 13,384 POSTS
the ground cable is bolted to the block !! if you have removed this bolt the check for wire clips along the wires !
Feb 17, 2009 at 5:12 AM
