1992 Ford Crown Victoria Trouble Starting
1992 FORD CROWN VICTORIA
LRTLBRT
Engine Mechanical problem
1992 Ford Crown Victoria V8 Two Wheel Drive Automatic
i started my car the other morning and let it run a few minute then put the car in drive, drove off and the car stop and would not restart. the starter rotate and rotate the engine but it wont catch,and the check temperature light comes on.
Dec 31, 2009 at 7:55 AM
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jan 1, 2010 at 7:06 AM
