1992 Ford Crown Victoria compression fittings on brake line
1992 FORD CROWN VICTORIA
100,000 MILES • V8 • 2WD • AUTOMATIC
JLEE1192
  • 4 POSTS
My car had new brake lines installed from master cylinder to both rear brakes by a certified repair facility. after noticing the lines were still leaking I had another shop look at them. The second shop would not work on it because compression fittings had been used to connect the lines in the middle of the car. I was told this was illegal and I needed to contact original shop, which they said there is no such law and would do nothing for me, unless I had written proof of such law. Is this true, I live in Michigan, is there any where I can find proof of this law on-line? Any help with this matter would be greatly appriciated. My daughter and her safety is on the LINE! Thanks again.
Jan 7, 2008 at 9:10 PM
FLEXY5
  • 512 POSTS
It is not so much a law as it is a regulated guideline set down by the Department of Transportation. The guideline states what fittings are proper for use on brake lines. I have seen compression fittings used with no negative affects, but I personally will not use them. Most States will not pass a vehicle through an inspection if it has a compression fitting on the brake line. My suggestion would be to check with your local DOT for clarifiction of proper fittings on brake lines. I hope this information helps you.
Dave
Jan 7, 2008 at 10:03 PM
BLACKOP555
  • 10,386 POSTS
YOUR IN LUCK, i live in michigan and there is no law like that, it is just a safety precaution, sounds to me like they dont want to mess around with your car!! take it to a different place to have them look at it.
Jan 7, 2008 at 10:56 PM
