1992 Ford Crown Victoria A/C Clutch or Compressor going bad
1992 FORD CROWN VICTORIA
111,278 MILES • V8 • 2WD • AUTOMATIC
LANCE43
  • 14 POSTS
When I engage the ac clutch it makes a Gog aweful noise. I quickly turn it off, then on, off etc.......
After a few times (3 or 4) the noise quits and runs normal fpr a while, then the air start to blow lukewarm.
If it's possible can you tell from what I described or can you tell how to tell which one is going bad, or is the whole thing (Compressor) going bad.
Thank You,
Aug 20, 2010 at 9:24 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
You may just have a simple loose belt, they will scream when a bit loose and as they heat up (friction from slipping) they will start to grip, check this out first, if it has been slipping you should consider replacing the belt as it will be damaged by now.
mark (mhpautos)
Aug 20, 2010 at 10:08 AM
LANCE43
  • 14 POSTS
Thank you I hope it's just the belt. I will give that a shot.
Aug 20, 2010 at 10:15 AM
MHPAUTOS
  • 31,937 POSTS
If it was a bearing or a pump problem, i just can't see the problem going away like that, let me know how you get on.
mark (mhpautos)
Aug 20, 2010 at 10:21 AM
