Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Ford
Crown Victoria
Engine
Idle Air Control
Replace/Remove
1987 Ford Crown Victoria replaced part same problem
1987 FORD CROWN VICTORIA
481,392 MILES • V8 • 2WD • AUTOMATIC
LAWRENCE311
MEMBER
FOLLOW
I replace the idle control valve. I am still having the same problem. car starts but then cuts right back off
Feb 20, 2008 at 1:10 PM
BMRFIXIT
CERTIFIED EXPERT
Clean throttle body
make sure all passages clean
check for vacuum leaks
check PCV valve
check and adjust base idle
Feb 20, 2008 at 2:12 PM
