1986 Ford Crown Victoria transmission gear selection indica
1986 FORD CROWN VICTORIA
97,000 MILES • V8 • 2WD • AUTOMATIC
ALANBEN
MEMBER
FOLLOW
Hi, the indicator does not come strictly in its places. Fluid level is ok. Please, Anatoly
Mar 25, 2008 at 1:35 PM
2CARPRO JACK
CERTIFIED EXPERT
Remove the trim panel directly under the steering column. There is a wheel where the cable attaches, use it to fine tune the indicator. If it still wont work properly, the indicator may need to be replaced
