1985 Ford Crown Victoria Car has no power
1985 FORD CROWN VICTORIA
180,000 MILES • V8 • 2WD • AUTOMATIC
SAKELLY1210
Recently I bumped another car and ever since the car hasn't run right. We replaced the fuel filter, did some clean up work on the injectors, replaced the rotor and cap, as well as the spark plugs. It at least will stay started now, but until you get it out of first gear has no power. Is the only thing that this could be the transmission or is there something else less expensive we can try first? I would appreciate any help I can get on this. thank you
Aug 27, 2009 at 4:15 PM
If it was in an accident, check to make sure the inside of the catylatic converter wasn't knocked loose and causing the problem. Also, has the check engine light come on? Have you checked fuel pump pressure?
Sep 10, 2009 at 1:42 PM
