1984 Ford Crown Victoria starting fluid
1984 FORD CROWN VICTORIA
100,000 MILES • V8 • 2WD • AUTOMATIC
REAPER7_59
  • 4 POSTS
car only starts when i use starting fluid in the throttle body.after that it runs fine all day until the next day.then i have to use the fluid again.can't figure it out.
Jun 4, 2008 at 10:14 AM
Do you hear the fuel pump come On when key at run position?-if not look for power on the orange wire on the fuel cut off inertia switch, no power there test out the fuel pump relay-if relay checks out its coming from the computer-
https://www.2carpros.com/forum/automotive_pictures/12900_inertia_switch_3.jpg
Jun 5, 2008 at 4:00 AM
