Unlike my Chevy & Dodge the hub & bearing assembly appears to be pressed on vs bollted on. Will it be necessary to unbolt the tie rod, swing arm and shock & spring assembly in order to remove the short shaft with the suspected bad cv joints?
FYI: This is a Contour SVT which may have a different suspension other than stock. I know the shock is custom because of the 'SVT' sticker on it
May 4, 2009 at 10:03 AM
