I have the car listed above 5 Speed with approximately 113,000 miles. It has been in and out of the mechanics and I have spent close to $800.00. My car bucks/hesitates whether going up hill or one a straight road. I replaced the fuel filter and the fuel pump. After that the check engine light came on. I took it back and he said the plug/sensor was corroded and not properly plugged in, he cleaned it and plugged it in properly. Once he cleaned the plug/sensor the check engine light went off, the next day it came back on. I was getting great gas mileage and figured it was a false reading. Today, the car is worse, it seems worse when it's a hot day, I can't use the A/C or the panel because when I do, the bucking/hesitation gets worse. Any suggestions? Thank you
May 4, 2007 at 1:55 PM
