Car ran fine until a couple days ago, when i noticed a slight hiccup in the idle no matter what gear I had selected. Whenever I apply any gas at all there seems to be no problems whatsoever. I already attempted carb cleaner searching with no luck and I can't find any signs of hissing or leaking from the vacuum lines. However, when I disconnect the wiring harness from the TPS, the idle is consistent but I think it is only because the idle is increased. Any ideas? Thanks,
Jan 21, 2009 at 8:14 PM
