1999 Ford Contour Rough/Erratic Idle
1999 FORD CONTOUR
116,000 MILES • 4 CYL • 2WD • AUTOMATIC
JONAS.CALSBEEK
  • 5 POSTS
Car ran fine until a couple days ago, when i noticed a slight hiccup in the idle no matter what gear I had selected. Whenever I apply any gas at all there seems to be no problems whatsoever. I already attempted carb cleaner searching with no luck and I can't find any signs of hissing or leaking from the vacuum lines. However, when I disconnect the wiring harness from the TPS, the idle is consistent but I think it is only because the idle is increased. Any ideas? Thanks,
Jan 21, 2009 at 8:14 PM
JWILLIAMS59
talked with ford tech pointed me in this direction. this sensor is controlled by oil if you are not vigilant with your oil changes this sensor becomes plugged. the dtc p1383 will be stoed on your computer.
Nov 19, 2009 at 4:20 PM
