1999 Ford Contour Erratic idling
1999 FORD CONTOUR
131,645 MILES • 4 CYL • FWD • AUTOMATIC
KYEMAUB
I am currently working on a '99 Ford Countour. I have just replaced all of the spark plugs, plug wires, timing belt, air filter, oil and oil filter, fuel filter and it is still idling very erratically. I hooked my OBDII scanner up and I don't come up with any codes. What should I do?
Sep 27, 2008 at 4:58 PM
For a start check the PCV and EGR valves and also the idle air control valve/motor and vacuum leaks. Possible the valve timing is off a notch or 2.
Check fuel pressure might not be within specs.
Sep 27, 2008 at 5:16 PM
