1999 Ford Contour brake lights and turn signal
1999 FORD CONTOUR
91,416 MILES • 4 CYL • 2WD • AUTOMATIC
SLAM49
my brake lights and turn signal donot work.I replaced the fuse,and the brake light sensor(on the brake pedal).The back window brake light works and parkinglights work.
Sep 13, 2009 at 11:33 AM
JDL
  • 16,098 POSTS
Welcome to the site, fuse 23--15 amp in the junction box under the hood, that fuse circuit should be hot with the key on, use a testlite to check if you haven't already. Your lower brake lites and turn signals use the same circuit, just not at the same time. Maybe a problem with turn switch or wiring circuit?
Sep 13, 2009 at 11:44 AM
