1998 Ford Contour transmission will not engage
1998 FORD CONTOUR
125,000 MILES • 6 CYL • FWD • MANUAL
DISANTO5
the trans will not engage any gear. shifter appears to be completley loose, i have confirmed the cable are not broken. pressing the clutch does not change a thing.
is there internal linkage or trans is shot?
Aug 20, 2009 at 7:04 PM
TRANSMAN1
  • 29 POSTS
Yes there is internal linkage on that trans axle.If you pull the shift cover off (where cables hook to trans) Look in there there is a part that breaks if no problem there it may be a internal problem assuming you checked to make sure everything is moving at trans when shifting shifter from inside car while some one watches linkage at trans.
Jan 6, 2010 at 6:58 PM
