1998 Ford Contour Starter Switch replacement instructions
1998 FORD CONTOUR
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
HEN2426
MEMBER
1 POST
FOLLOW
How to take the switch to get to the snappery.
Mar 13, 2010 at 10:27 AM
MERLIN2021
CERTIFIED EXPERT
I'm a bit confused about what you need, do you want to replace the ignition switch? This is not the lock and cylinder, but the plastic part the harness plugs into, or do you want to replace the cylinder? I dont know what a snapery is, can you explain?
