1998 Ford Contour SE V6 2.5L DOHC
1998 FORD CONTOUR
TOMTINA200
  • 6 POSTS
Hello, I would like to get some help before wasting more money. The "check engine soon" light came on and it gave 7 codes 5 pertaining to 02 sensors and 1 for the catalyc converter and 1 for the EGR...I swapped the 2 02 sensors in the car and now I am down to 3 codes but they are P0133 P0141 AND P0136 which they all pertain to the 02 sensors and the 02 heater circuit malfuntion. I check the fuses and yes the fuse on the engine compartment was blown and I replaced it. I went to Autozone again and once again the 3 codes came up the same one' now I am so confused what should I do and what do you think is wrong?? Please help and I am up to $150.00 is just two sensors......
Feb 26, 2007 at 5:14 PM
CHEVY22
  • 1,375 POSTS
hi
the 2.5 has 4 02 sensors two front and two rear , it looks like at least three were malfunctioning and you replaced two
let me know
jim
Feb 26, 2007 at 5:31 PM
TOMTINA200
  • 6 POSTS
Thanks for replying to my question, but were exactly on the engine they are located in..Please use relative location ex: before the catalyc converter or close to the water pump etc....I am sorry I am naive when it comes to automotive terms....
Feb 27, 2007 at 7:21 AM
CHEVY22
  • 1,375 POSTS
one in each manifold , they are hard to see , look from underneath , jiust follow the exhaust pipe up to the manifold
Feb 27, 2007 at 2:07 PM
TOMTINA200
  • 6 POSTS
Yes you were right they are located in each manifold. In case someone has a question like mine on same car If they click on the link they will find them very quickly. I found mine..Also do you know what the one in the back of the engine is called? I called Autozone and they claim that I am wrong the car only has 2 O2 sensors. I know it has 4 because I saw them and touched them with my hands....Thanks Chevy II you are the greatest...and also thanks 2car pros...I will make a donation..This is the best website and yes I will help you guys keep this one open for all of us out there that need your help...
Feb 27, 2007 at 2:14 PM
CHEVY22
  • 1,375 POSTS
GREAT IM GLAD YOU FOUND THEM , FOR ACTUALLY CALLS THEIRS DIIFERENT NAMES THAN MODT THEY UDE H02S 11 H02S 12 LEFT BANK SHOULD BE 11 RIGHT SHOULD BE 12 , BOTH FOR THE MANIFOLD ARE THE SAME ##
THANKS AND GOOD LUCK , OH AND DONT FORGET TO LEAVE ME SOME FEEDBACK , IT SHOWS YOUR APPRECIATION TO US WHO DONATE OUR TIME HERE
JIM
Feb 27, 2007 at 2:40 PM
