1998 Ford Contour Locating Bolts to remove the Alternator
1998 FORD CONTOUR
107,000 MILES • 4 CYL • FWD • AUTOMATIC
LIVING4FIRE
  • 4 POSTS
I have followed directions to remove the Alternator from my 98 Ford Contour and have gotten to the final steps of removing the bolts from the alternator. I have taken 2 bolts out that are the lower bolts (located right above my oil filter). I also located 2 bolts that I thought were the upper bolts, I removed one fully and the other is partially stuck due to the frame being in the way I cant pull it all the way out. Still at this point I would think I could move the alternator a bit, but it still feels as solid as if I hadnt taken any bolts out. Am I taking the correct bolts out of the alternator to remove it? Here is a picture I took showing the bolts that I think are the "Upper Bolts". Although the directions show only 1 bolt, which throws me off. Am I trying to remove the wrong ones, what am I missing?
[img:cafb45702e]http://www.2carpros.com/forum/automotive_pictures/137547_altern_1.jpg[/img:cafb45702e]
May 16, 2009 at 12:40 PM
LIVING4FIRE
  • 4 POSTS
Please disregard question. I was able to figure out that I did have the bolts removed and just needed to do some prying to break the alternator free from its bracket.
Is there any way I can get the $1 donation refunded?
Thanks much.
May 16, 2009 at 5:24 PM
KHLOW2008
  • 41,814 POSTS
Hi living4fire,
Sorry for the delay in answering.
I will inform the admin to get the refund back to you.
Thank you.
May 17, 2009 at 12:44 PM
THIS IS MIKE
  • 686 POSTS
Your donation has been refunded. We are sorry we could not help you this time.
May 18, 2009 at 11:25 AM
